Salta al contenuto principale
Samsung DV457GVGSWR LCD Touch Screen Replacement
Cosa ti serve
  1. Samsung DV457GVGSWR LCD Touch Screen Replacement, Preparations: passo 1, immagine 1 di 2 Samsung DV457GVGSWR LCD Touch Screen Replacement, Preparations: passo 1, immagine 2 di 2
    • Gather a few common tools: a small Philips head screwdriver (#1), a spudger or flathead screwdriver (any household size should work), and a 10mm socket on a 1/4 drive ratchet makes unscrewing the lid easy without having to pull the dryer too far from the wall.
    • UNPLUG THE DRYER
    • Pull the dryer away from the wall far enough to remove the two rear screws holding the lid on. The screws are located on the rear of the top panel about where the arrows point.
    • The recommended 10mm socket will help capture the screws so they don't fall down behind the dryer; but if you don't have a 10mm socket, you can use a stubby Philips screwdriver. Be careful not to drop the screws!
  2. Samsung DV457GVGSWR LCD Touch Screen Replacement, Open the machine's panel: passo 2, immagine 1 di 3 Samsung DV457GVGSWR LCD Touch Screen Replacement, Open the machine's panel: passo 2, immagine 2 di 3 Samsung DV457GVGSWR LCD Touch Screen Replacement, Open the machine's panel: passo 2, immagine 3 di 3
    • Slide the lid back a bit. It only has to move far enough to give you access to the screws. Remove the two screws at either end of the plastic rail.
    • Detach the panel by pressing up with your fingertips near the tabs shown by the arrows. It takes a little force, but not much. Once it's unhooked, lift the panel slightly and tip the top towards you.
    • Remove the four screws at the corners of the touch screen panel.
  3. Samsung DV457GVGSWR LCD Touch Screen Replacement, Remove the touch screen: passo 3, immagine 1 di 3 Samsung DV457GVGSWR LCD Touch Screen Replacement, Remove the touch screen: passo 3, immagine 2 di 3 Samsung DV457GVGSWR LCD Touch Screen Replacement, Remove the touch screen: passo 3, immagine 3 di 3
    • Disconnect the cable connecting the touch screen to the machine. Press the small tab to unlock the connector.
    • Press the connector halves apart using your thumb to push on the locking tab until they separate.
    • Use the flathead screwdriver to gently unlock the two tabs holding the top of the touch screen in place. Lift the touch screen assembly out of the panel.
Conclusione
Reassemble the dryer by reversing the steps above.
John Deters
Membro da: 08/15/11
99 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,095
