Salta al contenuto principale
Samsung DV300F Lens Replacement
Cosa ti serve
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, immagine 1 di 3 Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, immagine 2 di 3 Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, immagine 3 di 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: passo 2, immagine 1 di 2 Samsung DV300F Lens Replacement: passo 2, immagine 2 di 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: passo 3, immagine 1 di 3 Samsung DV300F Lens Replacement: passo 3, immagine 2 di 3 Samsung DV300F Lens Replacement: passo 3, immagine 3 di 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: passo 4, immagine 1 di 2 Samsung DV300F Lens Replacement, Back Button Control: passo 4, immagine 2 di 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: passo 5, immagine 1 di 1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: passo 6, immagine 1 di 2 Samsung DV300F Lens Replacement: passo 6, immagine 2 di 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: passo 7, immagine 1 di 2 Samsung DV300F Lens Replacement, Lens: passo 7, immagine 2 di 2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: passo 8, immagine 1 di 2 Samsung DV300F Lens Replacement: passo 8, immagine 2 di 2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Conclusione
Altre 5 persone hanno completato questa guida.
Baylor, Team 5-10, Williams Spring 2015 Membro di Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Membri
10 Guide realizzate
Un commento
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,774
