Introduzione
This guide will show you how to remove the casing around the device so that it and the parts underneath it can be replaced.
Cosa ti serve
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Altre 2 persone hanno completato questa guida.
