Salta al contenuto principale
Samsung DV180F Repair Display Screen Replacement
Cosa ti serve
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, immagine 1 di 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, immagine 2 di 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, immagine 3 di 3
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
    Chiedi a FixBot
  2. Samsung DV180F Repair Display Screen Replacement: passo 2, immagine 1 di 2 Samsung DV180F Repair Display Screen Replacement: passo 2, immagine 2 di 2
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
    Chiedi a FixBot
  3. Samsung DV180F Repair Display Screen Replacement: passo 3, immagine 1 di 3 Samsung DV180F Repair Display Screen Replacement: passo 3, immagine 2 di 3 Samsung DV180F Repair Display Screen Replacement: passo 3, immagine 3 di 3
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
    Chiedi a FixBot
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 14-4, Eyestone Fall 2016 Membro di USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Membri
8 guide realizzate
2Commenti sulla guida
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - Rispondi Condividi
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 42
Tutti i Tempi: 1,083
