Salta al contenuto principale
Samsung Chromebook XE550C22 Speakers Replacement
Cosa ti serve
  1. Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, immagine 1 di 3 Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, immagine 2 di 3 Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, immagine 3 di 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Speakers Replacement: passo 2, immagine 1 di 2 Samsung Chromebook XE550C22 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Speakers Replacement: passo 3, immagine 1 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 3, immagine 2 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 3, immagine 3 di 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Speakers Replacement: passo 4, immagine 1 di 2 Samsung Chromebook XE550C22 Speakers Replacement: passo 4, immagine 2 di 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Speakers Replacement, Battery: passo 5, immagine 1 di 2 Samsung Chromebook XE550C22 Speakers Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Speakers Replacement: passo 6, immagine 1 di 2 Samsung Chromebook XE550C22 Speakers Replacement: passo 6, immagine 2 di 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Speakers Replacement, Speakers: passo 7, immagine 1 di 1
    • Locate the speakers on the bottom left and right sides of the Chromebook.
  8. Samsung Chromebook XE550C22 Speakers Replacement: passo 8, immagine 1 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 8, immagine 2 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the fine tipped tweezers, detach the white power clips from the motherboard.
    • This may require some force, but be careful not to damage the cables.
  9. Samsung Chromebook XE550C22 Speakers Replacement: passo 9, immagine 1 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 9, immagine 2 di 3 Samsung Chromebook XE550C22 Speakers Replacement: passo 9, immagine 3 di 3
    • Insert the prying tool between the speaker and the Chromebook.
    • Slide the prying tool under the full length of the speaker, severing the glue underneath.
    • This may take some force.
  10. Samsung Chromebook XE550C22 Speakers Replacement: passo 10, immagine 1 di 2 Samsung Chromebook XE550C22 Speakers Replacement: passo 10, immagine 2 di 2
    • Remove the speaker by lifting it up and away from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Brenna Wolfe
Membro da: 09/11/17
541 Reputazione
3 Guide realizzate
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 242
