Salta al contenuto principale
Samsung Chromebook XE550C22 RAM Replacement
Cosa ti serve
  1. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: passo 1, immagine 1 di 3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: passo 1, immagine 2 di 3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: passo 1, immagine 3 di 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 RAM Replacement: passo 2, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement: passo 2, immagine 2 di 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 RAM Replacement: passo 3, immagine 1 di 3 Samsung Chromebook XE550C22 RAM Replacement: passo 3, immagine 2 di 3 Samsung Chromebook XE550C22 RAM Replacement: passo 3, immagine 3 di 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 RAM Replacement: passo 4, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement: passo 4, immagine 2 di 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 RAM Replacement, Battery: passo 5, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 RAM Replacement: passo 6, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement: passo 6, immagine 2 di 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 RAM Replacement, RAM: passo 7, immagine 1 di 1
    • Locate the RAM on the middle right side of the Chromebook.
  8. Samsung Chromebook XE550C22 RAM Replacement: passo 8, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement: passo 8, immagine 2 di 2
    • Using your fingers, separate the silver clips that are holding the RAM in place on each side.
    • The RAM will "pop-up" on its own after separating clips.
  9. Samsung Chromebook XE550C22 RAM Replacement: passo 9, immagine 1 di 2 Samsung Chromebook XE550C22 RAM Replacement: passo 9, immagine 2 di 2
    • Pull the RAM away from the Chromebook.
Conclusione
Altre 2 persone hanno completato questa guida.
Abel Osorio
Membro da: 09/11/17
330 Reputazione
2 Guide realizzate
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 687
