Salta al contenuto principale
Samsung Chromebook XE500C21-A03US Speakers Replacement
Cosa ti serve
  1. Samsung Chromebook XE500C21-A03US Speakers Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 2, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 2, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 2, immagine 3 di 3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 3, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 3, immagine 2 di 2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US Speakers Replacement, Speakers: passo 4, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Speakers Replacement, Speakers: passo 4, immagine 2 di 2
    • Use a blunt precision tweezer to remove the speaker cord from the R.A.M.
  5. Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 5, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 5, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Speakers Replacement: passo 5, immagine 3 di 3
    • Use the prying tool to find the divot then slowly add pressure until the speaker pops out.
    • Gently lift and remove the speaker from the Chromebook.
Conclusione
huy
Membro da: 09/11/17
337 Reputazione
3 Guide realizzate
CSU Fullerton, Team S2-G5, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G5, Bruce Fall 2017
CSUF-BRUCE-F17S2G5
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 155
