Salta al contenuto principale
Samsung Chromebook XE500C21-A03US Keyboard Replacement
Cosa ti serve
  1. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 2, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 2, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 2, immagine 3 di 3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 3, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 3, immagine 2 di 2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Speakers: passo 4, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Speakers: passo 4, immagine 2 di 2
    • Use a blunt precision tweezer to remove the speaker cord from the R.A.M.
  5. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 5, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 5, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 5, immagine 3 di 3
    • Use the prying tool to find the divot then slowly add pressure until the speaker pops out.
    • Gently lift and remove the speaker from the Chromebook.
  6. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Battery: passo 6, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  7. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 7, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 7, immagine 2 di 2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  8. Samsung Chromebook XE500C21-A03US Keyboard Replacement, RAM: passo 8, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, RAM: passo 8, immagine 2 di 2
    • Use a blunt precision tweezer to remove the speaker cord from the RAM
  9. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 9, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove all six 2.5 mm screws .
    • Start removing the screws from the wifi card.
  10. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 10, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 10, immagine 2 di 2
    • Gently lift the bottom of the wifi card then pull it towards you to disconnect it from the socket.
    • Our Chromebook does not have a circuit board. Remove all units connected to the circuit board if necessary.
  11. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 11, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 11, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 11, immagine 3 di 3
    • Gently lift the top left corner of the RAM and pull upward to remove it from the Chromebook.
  12. Samsung Chromebook XE500C21-A03US Keyboard Replacement, SD Card Reader: passo 12, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, SD Card Reader: passo 12, immagine 2 di 2
    • Remove both 3 mm screws using a Phillips #000 screwdriver.
  13. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 13, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 13, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 13, immagine 3 di 3
    • Remove the yellow tape on the left ribbon cable with a spudger.
    • Use a blunt precision tweezer to remove both ribbon cables attached to the SD card reader.
  14. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 14, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 14, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 14, immagine 3 di 3
    • Gently lift the top portion of the SD card reader and pull it away from you to remove it.
    • To reassemble, first insert the bottom of the SD card reader then carefully push downward.
  15. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: passo 15, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: passo 15, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: passo 15, immagine 3 di 3
    • Using a blunt precision tweezer, pull the white wire off the wificard.
    • Repeat step to remove the black wire to detach the wificard.
  16. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 16, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 16, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 16, immagine 3 di 3
    • Using the Phillips #00 screwdriver, remove all six 3.5 mm screws to detach the hinges from the keyboard.
    • The Chromebook displayed does not have all six screws.
  17. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 17, immagine 1 di 2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 17, immagine 2 di 2
    • Using the plastic spudger, place it under the hinge and pry it open.
    • Use your hand to lift the hinge.
    • Repeat on other side.
  18. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 18, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 18, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 18, immagine 3 di 3
    • Rotate the Chromebook 180 degrees so that the spine and hinges are facing you.
    • Lift the keyboard and trackpad upward.
  19. Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 19, immagine 1 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 19, immagine 2 di 3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: passo 19, immagine 3 di 3
    • Pull the keyboard and trackpad away from you to detach them from the spine of the Chromebook.
Conclusione
Altre 2 persone hanno completato questa guida.
CSU Fullerton, Team S2-G5, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G5, Bruce Fall 2017
CSUF-BRUCE-F17S2G5
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,846
