Salta al contenuto principale
Samsung Chromebook Series 3 Front Camera Replacement
Cosa ti serve
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, immagine 1 di 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, immagine 2 di 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: passo 2, immagine 1 di 3 Samsung Chromebook Series 3 Front Camera Replacement: passo 2, immagine 2 di 3 Samsung Chromebook Series 3 Front Camera Replacement: passo 2, immagine 3 di 3
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: passo 3, immagine 1 di 3 Samsung Chromebook Series 3 Front Camera Replacement: passo 3, immagine 2 di 3 Samsung Chromebook Series 3 Front Camera Replacement: passo 3, immagine 3 di 3
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: passo 4, immagine 1 di 1
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, immagine 1 di 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, immagine 2 di 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, immagine 3 di 3
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: passo 6, immagine 1 di 2 Samsung Chromebook Series 3 Front Camera Replacement: passo 6, immagine 2 di 2
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Conclusione
Tyler Schultz
Membro da: 03/25/19
528 Reputazione
3 Guide realizzate
IUPUI, Team S2-G1, Henning Spring 2019 Membro di IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
3 Membri
6 Guide realizzate
Un commento
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 401
