Introduzione
If your charger port is broken, this guide will teach you how to take apart your Chromebook and replace the faulty port.
Cosa ti serve
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
Altre 10 persone hanno completato questa guida.
