Salta al contenuto principale
Samsung Chromebook Series 3 Charging Port Replacement
Cosa ti serve
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Chromebook Series 3 Charging Port Replacement: passo 2, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 2, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Chromebook Series 3 Charging Port Replacement: passo 3, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 3, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 3, immagine 3 di 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Chromebook Series 3 Charging Port Replacement: passo 4, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 4, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 4, immagine 3 di 3
    • Pry off the bottom cover using a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, immagine 3 di 3
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Chromebook Series 3 Charging Port Replacement: passo 6, immagine 1 di 2 Samsung Chromebook Series 3 Charging Port Replacement: passo 6, immagine 2 di 2
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Chromebook Series 3 Charging Port Replacement: passo 7, immagine 1 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 7, immagine 2 di 3 Samsung Chromebook Series 3 Charging Port Replacement: passo 7, immagine 3 di 3
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Chromebook Series 3 Charging Port Replacement: passo 8, immagine 1 di 2 Samsung Chromebook Series 3 Charging Port Replacement: passo 8, immagine 2 di 2
    • You can now pull out the charging port module.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
UWT Liner: Group 1 Membro di UWT Liner: Group 1
Community
5 Membri
8 guide realizzate
2Commenti sulla guida
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Rispondi Condividi
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 68
Tutti i Tempi: 18,565
