Introduzione
Use the guide below to help you replace the hinge for the Samsung Chromebook Pro.
Cosa ti serve
Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
Altre 5 persone hanno completato questa guida.
6Commenti sulla guida
Great guide! One question: where can I buy the actual replacement hinge? Any tips?
I was able to find the hinges for mine on the Global Direct Parts web site. The item name is: OEM Samsung Chromebook Plus XE513C24, Pro XE510C24 Metal Hinge Set
The cables are just pushed into the side of the hinge. One side had a stopper holding the cable in place that I had to pull out, but the other had nothing holding the cable (that was the broken hinge on my chromebook, so maybe it had a stopper that had fallen out at one point). Once the stopper was removed from the one hinge, I could pull the cables out, and push them into new hinges.
Just replaced these hinges on my computer … was only a bit confused with the stopper in the hinge but otherwise this guide was extremely helpful. Took about 30 min to do …
