Salta al contenuto principale
Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement
Cosa ti serve
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: passo 1, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: passo 1, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: passo 1, immagine 3 di 3
    • Hold down the power button until the device powers off
    • Close the device and flip it over
    • Remove the four rubber sockets near the corners of the device
    • Then remove the four 4.6 mm Phillips #00 screws
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
    • Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 3, immagine 2 di 2
    • Locate the long grey box with the black band, which is labeled "Laptop Battery."
    • Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 4, immagine 1 di 1
    • Unplug the golden band coming from the battery to the motherboard.
    • Using the Philips #000 remove the four 4mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: passo 5, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: passo 5, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: passo 5, immagine 3 di 3
    • Face hinges towards you
    • Pull out the white plug-in piece
    • Only remove the red and black wire from the wire guide
    • If the left speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-C(L) R0.0 BA96-07326A"
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 6, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 6, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: passo 6, immagine 3 di 3
    • Only remove the white and black wire from the wire guide
    • If the right speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-A(R) R0.0 BA96-07326B"
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 55
