Salta al contenuto principale
Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement
Cosa ti serve
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Hold the power button on the keyboard until the device powers off.
    • Close the device and flip it over.
    • Remove the four rubber sockets on each corner of the device with your fingers.
    • Remove the four 4.6 mm screws with a Phillips #00 screwdriver.
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 2, immagine 2 di 2
    • Starting near the hinges, use a metal spudger to gently pry the back off. Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 3, immagine 2 di 2
    • Locate a long gray box labeled “Laptop Battery.”
    • Remove the two 4 mm screws with a Phillips #00 screwdriver.
    • After removing the screws, remove the gray piece labeled “bracket battery BA61 - 03983A.” This piece is located over the golden band connecting the battery and the motherboard.
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 4, immagine 1 di 1
    • Unplug the golden band that connects the battery to the motherboard.
    • Use the Phillips #000 screwdriver to remove the four 4 mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • Unplug the black and red wire and the black and white wire.
    • Unclip and remove the black and gold ribbons and the black wire from the motherboard.
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 6, immagine 1 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 6, immagine 2 di 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the three 4.53 mm Philips #00 screws from the grey metal piece labeled "BRKT-PORT-SUB JOAN-15 BA61-03942A".
    • Remove the 4.50 mm Philips #00 screw from the right side of the motherboard.
  7. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the two 4.56 mm Philips #00 screws from the copper heat sink.
    • Remove the four 4.63 mm Philips #00 screws
  8. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: passo 8, immagine 2 di 2
    • Carefully turn the motherboard and heat sink over being careful not to touch any of the components.
    • Remove the four 4.63 mm Philips #00 screws from the back of the motherboard and remove the heat sink.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 326
