Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K05US Speaker Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Place the Chromebook face down so the bottom case is uncovered.
    • Use the Phillips #00 screwdriver to remove all nine 4.6mm screws from the back case.
  2. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger or plastic opening tool to pry the case up from the vent on the hinge side of the Chromebook.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 3, immagine 1 di 1
    • Raise the case up and off the device.
  4. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 4, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 4, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 5, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 5, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 5, immagine 3 di 3
    • Remove one 4.9mm silver screw from each speaker.
  6. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 6, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 6, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 6, immagine 3 di 3
    • Use a spudger to gently push the cable connector sideways from the motherboard and the left speaker to disconnect the cable.
    • Remove the speaker.
  7. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 7, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: passo 7, immagine 2 di 2
    • Use a spudger to gently push the cable connector sideways from the motherboard and the right speaker to disconnect the cable.
Conclusione
Gateway, Team 4-4, Gonzalez Spring 2023 Membro di Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 88
