Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Battery: passo 4, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 5, immagine 3 di 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Remove the three 4.6mm screws from the silver port cover using a Phillips #00 screwdriver.
    • The port cover will take a little wiggling to lift up and out of the laptop.
  8. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the right speaker connector using a spudger.
  9. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 9, immagine 3 di 3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Slide the hinge out to remove it from the motherboard.
  10. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 10, immagine 2 di 2
    • Use a spudger to flip up the ZIF connector holding in the ribbon cable.
    • Once the ZIF connector has been lifted, slide the ribbon cable out of the motherboard.
  11. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 11, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 11, immagine 2 di 2
    • Slide the track pad ribbon cable out from the motherboard using a spudger.
  12. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 12, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 12, immagine 2 di 2
    • Lift the ZIF connector on the keyboard ribbon cable with a spudger.
    • Once the ZIF connector has been flipped, slide the ribbon cable out from the motherboard.
  13. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 13, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 13, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: passo 13, immagine 3 di 3
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
    • Ensure there are no cables in the way and lift the motherboard up and out of the laptop.
Conclusione
Un commento
Thanks for this. I was able to follow the steps and start up the Chromebook successfully. However, now my keyboard and mouse pad aren't working. I tried going back and reinserting the ribbon connectors a couple of times without success. If I plug in a separate mouse and keyboard, they both work. Anything else I should try?
Melissa Skilliter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,165
