Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: passo 1, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: passo 1, immagine 2 di 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
  4. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Remove the silver bracket.
  5. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Remove the 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Remove the wire connector from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Remove the black and white wires from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 8, immagine 2 di 2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  9. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: passo 9, immagine 1 di 1
    • Lift and remove the I/O board from the base of the laptop
Conclusione
Alex
Membro da: 03/28/23
178 Reputazione
1 Guida realizzata
IUPUI, Team 3-3, Harley Spring 2023 Membro di IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 160
