Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: passo 1, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: passo 1, immagine 2 di 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 2, immagine 2 di 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 3, immagine 3 di 3
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 4, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 4, immagine 2 di 2
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: passo 5, immagine 1 di 1
    • Remove the hinges from the bar on both sides.
Conclusione
Caden Smith
Membro da: 03/28/23
397 Reputazione
2 Guide realizzate
IUPUI, Team 3-3, Harley Spring 2023 Membro di IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 111
