Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: passo 3, immagine 2 di 2
    • Remove the cover exposing the inside of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 382
