Salta al contenuto principale
Samsung Chromebook 3 XE500C13-K02US Battery Replacement
Cosa ti serve
  1. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 3, immagine 2 di 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: passo 4, immagine 1 di 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 5, immagine 1 di 3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 5, immagine 2 di 3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 5, immagine 3 di 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery up and out of the case.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,626
