Salta al contenuto principale
Samsung Chromebook 3 Speakers Replacement
Cosa ti serve
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 Speakers Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: passo 2, immagine 1 di 3 Samsung Chromebook 3 Speakers Replacement: passo 2, immagine 2 di 3 Samsung Chromebook 3 Speakers Replacement: passo 2, immagine 3 di 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: passo 3, immagine 1 di 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: passo 4, immagine 1 di 2 Samsung Chromebook 3 Speakers Replacement, Speakers: passo 4, immagine 2 di 2
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: passo 5, immagine 1 di 3 Samsung Chromebook 3 Speakers Replacement: passo 5, immagine 2 di 3 Samsung Chromebook 3 Speakers Replacement: passo 5, immagine 3 di 3
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: passo 6, immagine 1 di 3 Samsung Chromebook 3 Speakers Replacement: passo 6, immagine 2 di 3 Samsung Chromebook 3 Speakers Replacement: passo 6, immagine 3 di 3
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: passo 7, immagine 1 di 3 Samsung Chromebook 3 Speakers Replacement: passo 7, immagine 2 di 3 Samsung Chromebook 3 Speakers Replacement: passo 7, immagine 3 di 3
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
Conclusione
Sarah Westberg
Membro da: 03/11/19
18.083 Reputazione
65 Guide realizzate
iFixit Membro di iFixit
Community
137 Membri
17.047 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 436
