Salta al contenuto principale
Samsung Chromebook 3 Daughterboard Replacement
Cosa ti serve
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: passo 2, immagine 1 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 2, immagine 2 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 2, immagine 3 di 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: passo 3, immagine 1 di 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: passo 4, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: passo 4, immagine 2 di 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: passo 5, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement: passo 5, immagine 2 di 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: passo 6, immagine 1 di 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: passo 7, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: passo 7, immagine 2 di 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement: passo 8, immagine 2 di 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: passo 9, immagine 1 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 9, immagine 2 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 9, immagine 3 di 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: passo 10, immagine 1 di 2 Samsung Chromebook 3 Daughterboard Replacement: passo 10, immagine 2 di 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: passo 11, immagine 1 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 11, immagine 2 di 3 Samsung Chromebook 3 Daughterboard Replacement: passo 11, immagine 3 di 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: passo 12, immagine 1 di 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
18.083 Reputazione
65 Guide realizzate
iFixit Membro di iFixit
Community
137 Membri
17.047 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,022
