Salta al contenuto principale
Samsung Chromebook 2 XE503c12 Motherboard Replacement
Cosa ti serve
  1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 5, immagine 1 di 1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Locate the motherboard at top right of chromebook.
    • Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
  7. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove auxiliary wires for microphone and webcam.
  8. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift hinge on connector up and pull the connector away from the device.
  9. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove the connector for the motherboard and sub-board.
  10. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the connector for motherboard and chromebook.
  11. Samsung Chromebook 2 XE503c12 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 489
