Introduzione
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
Cosa ti serve
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
Altre 2 persone hanno completato questa guida.
