Salta al contenuto principale
Samsung Captivate Rear Case Replacement
Cosa ti serve
  1. Samsung Captivate Rear Case Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: passo 2, immagine 1 di 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: passo 3, immagine 1 di 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: passo 4, immagine 1 di 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: passo 5, immagine 1 di 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: passo 6, immagine 1 di 3 Samsung Captivate Rear Case Replacement: passo 6, immagine 2 di 3 Samsung Captivate Rear Case Replacement: passo 6, immagine 3 di 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: passo 7, immagine 1 di 1
    • Separate the rear case from the phone.
Conclusione
Altre 12 persone hanno completato questa guida.
Christopher
Membro da: 10/06/11
643 Reputazione
4 Guide realizzate
Cal Poly, Team 20-25, Maness Fall 2011 Membro di Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,703
