Introduzione
How to remove the main speaker of the Samsung Captivate Glide.
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Aggiungi Commento
Remove battery with plastic opening tool or finger.
  • Remove battery with plastic opening tool or finger.
Aggiungi Commento
  • Remove the seven screws from backplate using the #00 screwdriver.
Aggiungi Commento
  • Remove the back plate using the plastic opening tool.
  • There is a lip on each side, and both must be pried up.
  • You can work your way around the edges after prying the two sides.
Aggiungi Commento
  • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
Aggiungi Commento
  • Disconnect the antenna cable from the motherboard using tweezers.
Aggiungi Commento
  • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
Aggiungi Commento
  • Lift the motherboard out of the base of the phone.
Aggiungi Commento
  • Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
Aggiungi Commento
  • Remove speaker manually.
  • There is nothing connecting it to the motherboard, so just pull.
Aggiungi Commento
Conclusione
Nicholas Mira
Membro da: 23/09/2014
280 Reputazione
2 Guide realizzate
USF Tampa, Team 5-3, Mcgee Fall 2014 Membro di USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 257
