Salta al contenuto principale
Samsung Captivate Glide QWERTY Keyboard Replacement
Cosa ti serve
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: passo 1, immagine 1 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: passo 1, immagine 2 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 2, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 3, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 3, immagine 2 di 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 4, immagine 1 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 4, immagine 2 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 4, immagine 3 di 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 5, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 8, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 8, immagine 2 di 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: passo 9, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: passo 9, immagine 2 di 2
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 10, immagine 1 di 2 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 10, immagine 2 di 2
    Compra
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 11, immagine 1 di 1
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 12, immagine 1 di 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 13, immagine 1 di 1
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 14, immagine 1 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 14, immagine 2 di 3 Samsung Captivate Glide QWERTY Keyboard Replacement: passo 14, immagine 3 di 3
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: passo 15, immagine 1 di 1
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 5-3, Mcgee Fall 2014 Membro di USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 439
