Salta al contenuto principale
Samsung Brightside Logic board Replacement
Cosa ti serve
  1. Samsung Brightside Logic board Replacement, Logic board: passo 1, immagine 1 di 3 Samsung Brightside Logic board Replacement, Logic board: passo 1, immagine 2 di 3 Samsung Brightside Logic board Replacement, Logic board: passo 1, immagine 3 di 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: passo 2, immagine 1 di 3 Samsung Brightside Logic board Replacement: passo 2, immagine 2 di 3 Samsung Brightside Logic board Replacement: passo 2, immagine 3 di 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: passo 3, immagine 1 di 3 Samsung Brightside Logic board Replacement: passo 3, immagine 2 di 3 Samsung Brightside Logic board Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: passo 4, immagine 1 di 3 Samsung Brightside Logic board Replacement: passo 4, immagine 2 di 3 Samsung Brightside Logic board Replacement: passo 4, immagine 3 di 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: passo 5, immagine 1 di 2 Samsung Brightside Logic board Replacement: passo 5, immagine 2 di 2
    • Detach the LCD connector.
    • Remove the logic board
Conclusione
oldturkey03
Membro da: 09/29/10
791.325 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
35 Membri
603 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,559
