Salta al contenuto principale
Samsung Blast Back Cover Replacement
Cosa ti serve
  1. Samsung Blast Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: passo 2, immagine 1 di 1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: passo 3, immagine 1 di 1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: passo 4, immagine 1 di 1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 190
