Salta al contenuto principale
Samsung Blackjack Volume/Scroll Wheel Replacement
Cosa ti serve
  1. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: passo 1, immagine 1 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: passo 1, immagine 2 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: passo 1, immagine 3 di 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: passo 2, immagine 1 di 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: passo 2, immagine 2 di 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: passo 3, immagine 1 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: passo 3, immagine 2 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: passo 3, immagine 3 di 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: passo 4, immagine 1 di 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: passo 4, immagine 2 di 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Volume/Scroll Wheel Replacement: passo 5, immagine 1 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement: passo 5, immagine 2 di 3 Samsung Blackjack Volume/Scroll Wheel Replacement: passo 5, immagine 3 di 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: passo 6, immagine 1 di 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: passo 6, immagine 2 di 2
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  7. Samsung Blackjack Volume/Scroll Wheel Replacement: passo 7, immagine 1 di 2 Samsung Blackjack Volume/Scroll Wheel Replacement: passo 7, immagine 2 di 2
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Conclusione
Kristin Manna
Membro da: 10/22/12
29 Reputazione
10 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 443
