Introduzione
Use this guide to remove the speaker.
Hold the device with the screen facing away from you and the camera towards you.
  • Hold the device with the screen facing away from you and the camera towards you.
  • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Aggiungi Commento
Place your fingers on both sides of the bottom of the battery and lift upwards.
  • Place your fingers on both sides of the bottom of the battery and lift upwards.
  • Pull the battery away from the phone.
Aggiungi Commento
  • Place your thumb on the SIM card.
  • Slide the card out of the slot.
Aggiungi Commento
  • Use the spudger to remove the rubber stoppers from the top of the cover.
  • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Aggiungi Commento
  • Use the spudger to loosen and separate the front and back covers.
  • Pick up the back cover once loosened.
  • The front and back covers will be attached to each other by a gold wire.
  • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Aggiungi Commento
  • Use the spudger to unsnap the black rectangular connection from the motherboard.
  • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
Aggiungi Commento
  • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
Aggiungi Commento
  • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
  • Lift up on the motherboard and it will come free of the front casing.
Aggiungi Commento
  • Use the spudger to wedge between the speaker and the speaker's casing.
  • Use the spudger to pry on the speaker until it comes free from the casing.
Aggiungi Commento
Conclusione
Kristin Manna
Membro da: 22/10/2012
17 Reputazione
10 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 291
