Salta al contenuto principale
Samsung Blackjack Motherboard Replacement
Cosa ti serve
  1. Samsung Blackjack Motherboard Replacement, Back Phone Casing: passo 1, immagine 1 di 2 Samsung Blackjack Motherboard Replacement, Back Phone Casing: passo 1, immagine 2 di 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  2. Samsung Blackjack Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Blackjack Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Blackjack Motherboard Replacement: passo 2, immagine 3 di 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  3. Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: passo 3, immagine 1 di 2 Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: passo 3, immagine 2 di 2
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  4. Samsung Blackjack Motherboard Replacement: passo 4, immagine 1 di 2 Samsung Blackjack Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  5. Samsung Blackjack Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Samsung Blackjack Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  6. Samsung Blackjack Motherboard Replacement: passo 6, immagine 1 di 2 Samsung Blackjack Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  7. Samsung Blackjack Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Blackjack Motherboard Replacement: passo 7, immagine 2 di 2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
Conclusione
Kristin Manna
Membro da: 10/22/12
29 Reputazione
10 Guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 472
