Introduzione
Use this guide to replace a broken or damaged antenna.
Cosa ti serve
Hold the device with the screen facing away from you and the camera towards you.
Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Place your fingers on both sides of the bottom of the battery and lift upwards.
Pull the battery away from the phone.
Use the spudger to remove the rubber stoppers from the top of the cover.
Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Use spudger to help loosen the antenna.
Once the antenna is loose, use tweezers to remove antenna.
