Introduzione
Use this guide to install, remove, or replace the phone's keypad.
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Aggiungi Commento
Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
Aggiungi Commento
  • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
  • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
Aggiungi Commento
  • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
Aggiungi Commento
  • Insert the plastic opening tool in the gap between the back panel and rest of the body.
  • Slide the tool along the edges until the two pieces come apart.
  • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
Aggiungi Commento
  • Pry apart the plastic tabs along the edges of the phone.
  • Separate the front panel from the main body of the phone using your fingers.
Aggiungi Commento
  • Peel back the rubber keypad from the front casing.
Aggiungi Commento
Conclusione
Ryan Rumsey
Membro da: 30/01/2013
8 Reputazione
6 Guide realizzate
Cal Poly, Team 20-1, Maness Winter 2013 Membro di Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 242
