Salta al contenuto principale
Samsung BD-JM57C Power Cord Replacement
Cosa ti serve
  1. Samsung BD-JM57C Power Cord Replacement, Top Cover: passo 1, immagine 1 di 2 Samsung BD-JM57C Power Cord Replacement, Top Cover: passo 1, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Power Cord Replacement, Disc Drive: passo 2, immagine 1 di 2 Samsung BD-JM57C Power Cord Replacement, Disc Drive: passo 2, immagine 2 di 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Power Cord Replacement: passo 3, immagine 1 di 2 Samsung BD-JM57C Power Cord Replacement: passo 3, immagine 2 di 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Power Cord Replacement, WiFi Card: passo 4, immagine 1 di 2 Samsung BD-JM57C Power Cord Replacement, WiFi Card: passo 4, immagine 2 di 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Power Cord Replacement, Power Cord: passo 5, immagine 1 di 2 Samsung BD-JM57C Power Cord Replacement, Power Cord: passo 5, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Power Cord Replacement: passo 6, immagine 1 di 1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Power Cord Replacement: passo 7, immagine 1 di 1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Power Cord Replacement: passo 8, immagine 1 di 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 156
