Salta al contenuto principale
Samsung BD-JM57C Motherboard Replacement
Cosa ti serve
  1. Samsung BD-JM57C Motherboard Replacement, Top Cover: passo 1, immagine 1 di 2 Samsung BD-JM57C Motherboard Replacement, Top Cover: passo 1, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Motherboard Replacement, Disc Drive: passo 2, immagine 1 di 2 Samsung BD-JM57C Motherboard Replacement, Disc Drive: passo 2, immagine 2 di 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Motherboard Replacement: passo 3, immagine 1 di 2 Samsung BD-JM57C Motherboard Replacement: passo 3, immagine 2 di 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Motherboard Replacement, Power Cord: passo 4, immagine 1 di 2 Samsung BD-JM57C Motherboard Replacement, Power Cord: passo 4, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  5. Samsung BD-JM57C Motherboard Replacement: passo 5, immagine 1 di 1
    • Push in the small white lever and pull it towards you to release the cord.
  6. Samsung BD-JM57C Motherboard Replacement: passo 6, immagine 1 di 1
    • Move the power cord out from under the metal tab on the side of the case.
  7. Samsung BD-JM57C Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  8. Samsung BD-JM57C Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  9. Samsung BD-JM57C Motherboard Replacement: passo 9, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  10. Samsung BD-JM57C Motherboard Replacement: passo 10, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 521
