Salta al contenuto principale
Samsung BD-JM57C Disc Drive Replacement
Cosa ti serve
  1. Samsung BD-JM57C Disc Drive Replacement, Top Cover: passo 1, immagine 1 di 2 Samsung BD-JM57C Disc Drive Replacement, Top Cover: passo 1, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Disc Drive Replacement, Disc Drive: passo 2, immagine 1 di 2 Samsung BD-JM57C Disc Drive Replacement, Disc Drive: passo 2, immagine 2 di 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Disc Drive Replacement: passo 3, immagine 1 di 2 Samsung BD-JM57C Disc Drive Replacement: passo 3, immagine 2 di 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 868
