Salta al contenuto principale
Samsung BD-H5100 Motherboard Replacement
Cosa ti serve
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung BD-H5100 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung BD-H5100 Motherboard Replacement: passo 2, immagine 3 di 3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: passo 3, immagine 1 di 2 Samsung BD-H5100 Motherboard Replacement: passo 3, immagine 2 di 2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: passo 5, immagine 1 di 2 Samsung BD-H5100 Motherboard Replacement: passo 5, immagine 2 di 2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: passo 6, immagine 1 di 2 Samsung BD-H5100 Motherboard Replacement: passo 6, immagine 2 di 2
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung BD-H5100 Motherboard Replacement: passo 7, immagine 2 di 2
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: passo 9, immagine 1 di 1
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: passo 10, immagine 1 di 1
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
Conclusione
Mira Patel
Membro da: 10/11/16
580 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Leahy Fall 2016 Membro di USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 523
