Salta al contenuto principale
Samsung BD-H5100 Disk Reader Replacement
Cosa ti serve
  1. Samsung BD-H5100 Disk Reader Replacement, Disk Reader: passo 1, immagine 1 di 1
    • Use the Phillips Head #2 screwdriver to remove the three 10 mm screws on the back panel.
  2. Samsung BD-H5100 Disk Reader Replacement: passo 2, immagine 1 di 3 Samsung BD-H5100 Disk Reader Replacement: passo 2, immagine 2 di 3 Samsung BD-H5100 Disk Reader Replacement: passo 2, immagine 3 di 3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Disk Reader Replacement: passo 3, immagine 1 di 2 Samsung BD-H5100 Disk Reader Replacement: passo 3, immagine 2 di 2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Disk Reader Replacement: passo 4, immagine 1 di 1
    • Remove the two 7.5 mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Disk Reader Replacement: passo 5, immagine 1 di 2 Samsung BD-H5100 Disk Reader Replacement: passo 5, immagine 2 di 2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Disk Reader Replacement: passo 6, immagine 1 di 1
    • Flip the disk tray upside down.
  7. Samsung BD-H5100 Disk Reader Replacement: passo 7, immagine 1 di 1
    • Use the Phillips Head #00 screwdriver to remove the four 6.2 mm corner screws.
  8. Samsung BD-H5100 Disk Reader Replacement: passo 8, immagine 1 di 1
    • Flip the disk reader up like a flip phone.
    • Be careful not to break the ribbon.
  9. Samsung BD-H5100 Disk Reader Replacement: passo 9, immagine 1 di 2 Samsung BD-H5100 Disk Reader Replacement: passo 9, immagine 2 di 2
    • Pull the ribbon out gently from one corner by the blue tab.
Conclusione
Mira Patel
Membro da: 10/11/16
580 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Leahy Fall 2016 Membro di USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 635
