Salta al contenuto principale
Samsung BD-F5900 WiFi Module Replacement
Cosa ti serve
  1. Samsung BD-F5900 WiFi Module Replacement, Top Cover: passo 1, immagine 1 di 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 WiFi Module Replacement: passo 2, immagine 1 di 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 WiFi Module Replacement, WiFi Module: passo 3, immagine 1 di 1
    • Disconnect the WiFi board cable connector from the main logic board
  4. Samsung BD-F5900 WiFi Module Replacement: passo 4, immagine 1 di 1
    • Using a #1 Phillips head screwdriver, remove the 7.5 mm screw.
    • Slightly tilt the WiFi module sideways to remove from chassis.
Conclusione
Louis McKean
Membro da: 10/18/17
528 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G21, Cagle Fall 2017 Membro di USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 198
