Salta al contenuto principale
Samsung BD-F5700 Power Cord Replacement
Cosa ti serve
  1. Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, immagine 2 di 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: passo 1, immagine 3 di 3
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Power Cord Replacement: passo 2, immagine 1 di 3 Samsung BD-F5700 Power Cord Replacement: passo 2, immagine 2 di 3 Samsung BD-F5700 Power Cord Replacement: passo 2, immagine 3 di 3
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Power Cord Replacement: passo 3, immagine 1 di 2 Samsung BD-F5700 Power Cord Replacement: passo 3, immagine 2 di 2
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Power Cord Replacement: passo 4, immagine 1 di 1
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
Conclusione
USF Tampa, Team S16-G4, Boczar Spring 2018 Membro di USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 304
