Salta al contenuto principale
Samsung BD-E5400 Wi-Fi Card Replacement
Cosa ti serve
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: passo 1, immagine 1 di 2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: passo 1, immagine 2 di 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: passo 3, immagine 1 di 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: passo 3, immagine 2 di 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: passo 3, immagine 3 di 3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
Conclusione
IUPUI, Team S1-G3, Arle Fall 2018 Membro di IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Membri
4 Guide realizzate
Un commento
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 277
