Introduzione
Nothing is more frustrating that the useless whir of a disk drive that will not read your disk. In this guide, we will show you how to replace your disk drive!
Cosa ti serve
Remove the two 10mm Phillips #1 screws.
Remove the one 8 mm Phillips #1 screw.
Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
Remove both wire bundles from motherboard.
Depress tabs located on each side of disk drive as shown.
