Salta al contenuto principale
Samsung BD-E5400 Disk Drive Replacement
Cosa ti serve
  1. Samsung BD-E5400 Disk Drive Replacement, Outer Cover: passo 1, immagine 1 di 2 Samsung BD-E5400 Disk Drive Replacement, Outer Cover: passo 1, immagine 2 di 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Disk Drive Replacement: passo 2, immagine 1 di 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Disk Drive Replacement, Disk Drive: passo 3, immagine 1 di 2 Samsung BD-E5400 Disk Drive Replacement, Disk Drive: passo 3, immagine 2 di 2
    • Remove both wire bundles from motherboard.
    • Depress tabs located on each side of disk drive as shown.
  4. Samsung BD-E5400 Disk Drive Replacement: passo 4, immagine 1 di 1
    • Push entire disk drive forward.
    • Remove disk drive and replace.
Conclusione
IUPUI, Team S1-G3, Arle Fall 2018 Membro di IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 656
