Salta al contenuto principale
Samsung BD-D5500 Disc Tray Replacement
Cosa ti serve
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: passo 1, immagine 1 di 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: passo 2, immagine 1 di 2 Samsung BD-D5500 Disc Tray Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: passo 3, immagine 1 di 1
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: passo 4, immagine 1 di 1
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: passo 5, immagine 1 di 1
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: passo 6, immagine 1 di 1
    • Return it face up and the disc tray will slide out.
Conclusione
Brandon Nelson
Membro da: 01/29/18
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,044
