Salta al contenuto principale
Samsung Alias 2 Logic Board Replacement
Cosa ti serve
  1. Samsung Alias 2 Logic Board Replacement, Battery: passo 1, immagine 1 di 1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Logic Board Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
  3. Samsung Alias 2 Logic Board Replacement, Logic Board: passo 3, immagine 1 di 1
    • Remove the (4) 4.2 mm screws from the four corners of the battery slot.
  4. Samsung Alias 2 Logic Board Replacement: passo 4, immagine 1 di 1
    • Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Note: The tab is stuck on there with glue, this is alright, just peel it off.
  5. Samsung Alias 2 Logic Board Replacement: passo 5, immagine 1 di 1
    • Remove the (3) newly uncovered 4.3 mm screws.
  6. Samsung Alias 2 Logic Board Replacement: passo 6, immagine 1 di 1
    • Remove the back outside casing using the plastic opening tool.
    • Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
  7. Samsung Alias 2 Logic Board Replacement: passo 7, immagine 1 di 1
    • Pull up on the yellow tab.
  8. Samsung Alias 2 Logic Board Replacement: passo 8, immagine 1 di 1
    • Disconnect connecting cord using tweezers.
  9. Samsung Alias 2 Logic Board Replacement: passo 9, immagine 1 di 1
    • Disconnect rectangular ribbon.
  10. Samsung Alias 2 Logic Board Replacement: passo 10, immagine 1 di 1
    • Remove logic board.
Conclusione
Chris
Membro da: 04/16/11
133 Reputazione
5 Guide realizzate
Cal Poly, Team 12-35, Maness Spring 2011 Membro di Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,730
