Salta al contenuto principale
Samsung Admire Screen Replacement
Cosa ti serve
  1. Samsung Admire Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Slide your fingernail or plastic opening tool under the slit and pull the cover up.
  2. Samsung Admire Screen Replacement: passo 2, immagine 1 di 1
    • Place your fingernail or plastic tool into the hole beneath the camera and carefully lift out the battery.
  3. Samsung Admire Screen Replacement: passo 3, immagine 1 di 3 Samsung Admire Screen Replacement: passo 3, immagine 2 di 3 Samsung Admire Screen Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #00 precision screwdriver to remove the six screws from the back of the phone.
  4. Samsung Admire Screen Replacement: passo 4, immagine 1 di 3 Samsung Admire Screen Replacement: passo 4, immagine 2 di 3 Samsung Admire Screen Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to remove the inside back cover.
    • Use the plastic opening to pry the front and the back case apart.
    • As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
    • Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Screen Replacement: passo 5, immagine 1 di 3 Samsung Admire Screen Replacement: passo 5, immagine 2 di 3 Samsung Admire Screen Replacement: passo 5, immagine 3 di 3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
  6. Samsung Admire Screen Replacement: passo 6, immagine 1 di 3 Samsung Admire Screen Replacement: passo 6, immagine 2 di 3 Samsung Admire Screen Replacement: passo 6, immagine 3 di 3
    • Pull back on the five clips on the sides of the phone to remove the shield.
    • Be careful not to break the ribbon cables.
  7. Samsung Admire Screen Replacement: passo 7, immagine 1 di 3 Samsung Admire Screen Replacement: passo 7, immagine 2 di 3 Samsung Admire Screen Replacement: passo 7, immagine 3 di 3
    • Use the plastic opening tool to unlatch the ribbon cable to disconnect it.
    • Place the plastic opening tool under the edge of the screen and lift the screen up carefully.
  8. Samsung Admire Screen Replacement: passo 8, immagine 1 di 1
    • Insert new screen into the phone frame and reconnect the ribbon cable.
    • Follow steps in reverse order (omitting step eight) to reassemble the phone.
Conclusione
Altre 12 persone hanno completato questa guida.
Thao Uyen Do
Membro da: 01/20/15
896 Reputazione
4 Guide realizzate
USF Tampa, Team 7-5, Remmell Winter 2015 Membro di USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,649
