Salta al contenuto principale
Samsung Admire Camera Replacement
Cosa ti serve
  1. Samsung Admire Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Samsung Admire Camera Replacement, Remove the Battery: passo 2, immagine 1 di 1
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  3. Samsung Admire Camera Replacement, Remove the screws: passo 3, immagine 1 di 3 Samsung Admire Camera Replacement, Remove the screws: passo 3, immagine 2 di 3 Samsung Admire Camera Replacement, Remove the screws: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
  4. Samsung Admire Camera Replacement, Inside back Cover: passo 4, immagine 1 di 3 Samsung Admire Camera Replacement, Inside back Cover: passo 4, immagine 2 di 3 Samsung Admire Camera Replacement, Inside back Cover: passo 4, immagine 3 di 3
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
  5. Samsung Admire Camera Replacement, Motherboard: passo 5, immagine 1 di 3 Samsung Admire Camera Replacement, Motherboard: passo 5, immagine 2 di 3 Samsung Admire Camera Replacement, Motherboard: passo 5, immagine 3 di 3
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
  6. Samsung Admire Camera Replacement, Camera: passo 6, immagine 1 di 2 Samsung Admire Camera Replacement, Camera: passo 6, immagine 2 di 2
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
Conclusione
Altre 11 persone hanno completato questa guida.
Thao Uyen Do
Membro da: 01/20/15
896 Reputazione
4 Guide realizzate
USF Tampa, Team 7-5, Remmell Winter 2015 Membro di USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,530
