Salta al contenuto principale
Samsung Ace Keyboard Replacement
Cosa ti serve
  1. Samsung Ace Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Samsung Ace Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Samsung Ace Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Keyboard Replacement: passo 2, immagine 1 di 1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Keyboard Replacement: passo 3, immagine 1 di 1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Keyboard Replacement, Casing: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Keyboard Replacement: passo 5, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 5, immagine 2 di 2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Keyboard Replacement: passo 6, immagine 1 di 1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Keyboard Replacement: passo 7, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 7, immagine 2 di 2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Keyboard Replacement: passo 8, immagine 1 di 1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Keyboard Replacement: passo 9, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 9, immagine 2 di 2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Keyboard Replacement: passo 10, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 10, immagine 2 di 2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Keyboard Replacement: passo 11, immagine 1 di 1
    • Your front casing and front speaker are now released.
  12. Samsung Ace Keyboard Replacement, Keyboard: passo 12, immagine 1 di 1
    • Remove the keypad and place it to the side.
  13. Samsung Ace Keyboard Replacement: passo 13, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 13, immagine 2 di 2
    • Insert the flat edge of the spudger to the space under the keypad and slide it along the bottom to lift the keypad out of its place. The keypad should be stuck to the surface very tightly.
  14. Samsung Ace Keyboard Replacement: passo 14, immagine 1 di 2 Samsung Ace Keyboard Replacement: passo 14, immagine 2 di 2
    • The keypad will lift off the adhesive.
    • Be aware of the wires still connected on the right side of the phone.
Conclusione
Cal Poly, Team 6-24, Amido Spring 2012 Membro di Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Membri
17 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,100
