Salta al contenuto principale
Samsung ATIV Book 9 Plus Speakers Replacement
Cosa ti serve
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: passo 3, immagine 1 di 2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: passo 3, immagine 2 di 2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: passo 4, immagine 1 di 2 Samsung ATIV Book 9 Plus Speakers Replacement: passo 4, immagine 2 di 2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: passo 5, immagine 1 di 1
    • Gently tug on the white connector in order to remove the speakers.
Conclusione
Baylor, Team 2-3, Grigsby Spring 2015 Membro di Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,480
